Mounting Amp Behind Door Card
Hi,
I am planning on reinstalling my speaker amp, behind a rear panel, I just wondered if it possible, haven't taken it off too check. Can a small amp fit back there, on a fitted piece of MDF??
Just want it out of the boot as I need space for sub instal.
  Clio
pretty sure it could mate! glad to see some one doing something different. if you looking to fit it into the the door cards i think abit of fabrication work will need to be done tho as you will need to cut them.
Looking to either install my amps on the roof (Inside!) or the rear doorcards to.
  Ph1 172 + Combo van
i wouldnt want to put it in there because they get quite hot so u need to make some holes somewhere in the door card for ventilation!!!
