Hummmmmm sounds strange !!....lets explain how things should work
If you put you key in & turn 1 position(click)....this should work the accessories...ie radio etc........on the next position (click) the oil level gauge should work (& stay on) the fuel gauge should work...the outside temp gauge should work........you should have 3 red lights on (oil,hand brake & battery) & the coolant light should be on..<--- all of thease stay on until the next position !!....you should have also heard your fuel pump prime its self...(little short wirring noise from rear)
Then on the third position (click) the starting position........the engine should start & you let it fall back to the second position...........the oil gauge should drop to zero as soon as the engine has started.........if it dont ..theres probubaly somthing wrong with the sender unit !!...dont worry.they are only £50 !!
....anyway where was i ??...ho yes....the three main lights & the coolant light should turn off & you should have an oil (bar) pressure reading.................well.......any deveation from the above information.......then somthings wrong .......dont yer just love clio 16vs now eh ??......well you could have had a power steering pipe burst on the way home from castle coombe............i did !!!.......ho well.....off to renualt to order yet another new pipe !!!.......somthing strange here.....i feel like ive got my old R5GTT back...that bloddy thing always had pipes going on me......usually coolant pipes !!........blah blah blah....moan moan moan.....whinge whinge .....ta ta.....
http://www.stopstart.freeserve.co.uk/smilie/boohoo.gif
owwwww i forgot to say...the eratic readings from the oil gauge......if you get a certian level reading.....start your car..then turn off & get a different reading.....its prob because some of you oil has been pumped round your engine...until it falls back down into the sump you aint gonna get the same reading are yah !!!
unless yer sender units buggered.....then itll be all over the shop wont it !!!
