Odyssey PH1
Hi guys have had a search about but not really getting anywhere, i have just fitted new mintex discs and pads to the rear with new pressed in bearings as the old ones were both shot, i noticed that the discs had a bit of play once the hub nut was tight and noticed score marks on the insides of the old discs where they were catching on the hub, now when taking a sharp left turn there is a knocking noise from the rear. I had a search around and found that you need the small spacers for the discs as mine didnt seem to have any, after attempting to fit them last night i found that they sorted the problem but now the caliper bolts don't line up, i tried the spacer both ways and it sat the same. Could it be the fact im using non-genuine discs? or something else...
Any help will be much appreciated.
Thanks, Tom.
Thanks, Tom.
