2005 Clio 182 FF
I changed the front and rear dampers and installed new top mounts and modified top hat on my 182 ff.
I'm now getting a rattle at the front offside when driving, it seems to go away after about 10 mins? I Havnt had a chance to check it yet , I'm going to do this after work today. Top mounts were torqued to 20nm and lower strut bolts 105nm.
I used copper grease as a assembly grease when putting it back together, I hear this is incorrect ? Is it because of galvanic corrosion or what's the story with it? Ill clean it off if it's going to cause mayhem.
