PH1 172
Fitted my 172 gaz coilovers today. Did the fronts fine etc but when going to do the back i ran into a rather big problem - no matter how or what we try we cannot get the top bolt on when both rubber (lower and upper) bushes are on.
I attached both shocks at the bottom with the one long bolt - dropped the car down (springs are at their lowest) and fed the shock up through the hole. Pulled the shock up through to put the upper bush on but once it is on its not even close to being able to get the top bolt on.
Tried jacking the wheel up etc but no luck.
WHen i pull the shock out and look at the lower rubber bush it is seated properly and up fine - but when puttin the top one on and pulling it up through the thread simply doesnt seem big enough - any ideas?
Need it fixed asap!
Ross
Need it fixed asap!
Ross
