Removing Air-Con on 197
  Albi Blue 197
I know you cant just remove the air con on the 197s because the auxiliary belt is part of it, but is it possible to get a custom made auxiliary belt made up that once you take out the air con the belt just operates everything else. If so, what places make custom auxiliary belts?
Reece..
  TrackCar & F30 330d
Can you not just get a piece of string, measure how big the belt should be and how many ribs you need and then just get a shorter belt from halfords which best matches your measurements?
