its easyer to remove them by going under the car and undoing the 4 bolts and the seats & Subframe comes out in one so then you get more access to get the subframes off.
1- Car on ramps
2- disconnect battery earth
3- get under car with a 17mm socket (long one)
4- remove rubber grommets from outsitde bolt holes and remove bolts
5- remove bolts located behind exhaust heatsheild (there should be access holes in heatshield).
6- lift whole seat up an inch and it will be free.
7- let seat flop over backwards
8- disconnect airbag/pre-tensioner plugs
9- remove seat
what u taking the seats out of paul??? if its a valver then its 13mm bolts (2 in exhaust channel under the car and 2 inside the car closest to the doors) give me a bell if u get stuck
what a real pain in the arse that seems to me! so much easier in my current car 4 star shape bolts and they are out hehe. typical shitroen build! everything comes out nice a easy with like 2-4 bolts or just pulls off lol, role on a clio at Christmas!
