Sleeved decat problem
  RB 182 Cup
Hi all!
Just received my sleeved janspeed decat pipe to go with the janspeed cat-back system,
All was going fine whilst removing the Cat until it was time to pull out the adaptor from the centre section which clamps the centre section to the Cat,
For the life of me I can't get this thing out!
Anyone else had this problem?
Any suggestions?
  monaco 172
right
disconnect cat and remove
put the olive joint clamp on the end of the adapter (joint end) and tighten it back up like you would if the cat was there
wack it hard with a hammer (toward the front of the car obviously)
keep wacking untill it comes out of the center section
then slide your decat pipe in (will probs need tapping in with hammer)
