ford fiesta 2004
Hello All,
hopefully I will be a very happy man on Tuesday and will be the owner of a 182 track toy. the current owner has done a great job and the spec is almost what I would want for a road legal track car.
I'm trying to work out budget for a couple of bits I would like however I have some questions that I know you guys can answer.
The car is stripped however it is currently missing a roll cage and harnesses, I will certainly be ordering the ebay cage from Alan but wanted to see how you guys painted it. I was looking to do this myself but wanted to get your opinions. I have painted strut braces before using hammerite smooth with some really good results, is this good enough for the cage? ideally id like to have it powder coated however saving on the pennies is always good.
Secondly I would need some 4 point harnesses with the Jet fighter style buckle, any recommendations don't want to spend a fortune.
Regarding the eyelet bolts am I right in saying that I can use the current holes by the door using an m10 size bolt? then on the other side is it the hole by the handbrake? what size hole is it.
Car has the ds2500 pads which I hear are great however can potentially fade on track days, the plan would be to sort out the fog lights with the ebay brake cooling kit however will the ds2500 still be able to keep up? ideally I would like the ds1.11.
I think that's all of the questions I had for now. sure more will come when I actually have the car in my hands
cheers
Dan
cheers
Dan
