Speed sensor connector plug
  Clio 172 Ph1
Does anyone know if you can buy the connector plug that is on the wiring loom that connects into the speed sensor on the gearbox housing ?
Mine has melted & caused a short so need to find one to solder back onto the loom, not sure what the connector is called but it is female and has 3 pins, the top pin is connected to the yellow wire, left side pin connected to white wire & right side pin connected to black wire
