Hi guys, I have a stutter occuring at light loads between 1500-2500rpm around 30-40mph on my ph1 turbo
And idea's?
The injectors all read 14ohms when checking resistance, however this doesn't cancel them out as being the problem.
It has a new adaptronic coilpack, new r26 genuine plugs, new leads, I have checked throttle position when connected to ecu and it doesn't seem to be throttle position sensor. I run open loop fuelling so the lambda is essentially turned off I believe so isn't this either.
Any input on what to check is appreciated
And idea's?
