Sub Keeps Moving Help
  197 cup
Any 1 got any suggestions for me to stop my sub from moving about the boot all the time. Ive heard that using velcro may help but does any 1 have any other idea cheers
  Pulsar Gti-r,LY 182
i used a mini football to wedge the box in means you can get a kick about when ever you want too:cool:
My sub is screwed in the back of rear seats and sits on top of the plastic thing at bottom so if i need to change wheel i still can, win.
koi
  Audi S1
Be better making an mdf floor and screwing it down, wouldn't fancy a flying sub in an accident
  monaco 172
its the only way to do it. i stappled it to the box and carpet hasnt moved once. make sure you get 50mm stuff
S23
  The Cleee-O
I've got rachet straps going to the isofix bar on mine, bright orange and it doesn't move an ounce :) lol
  Listerine & Poledo
I've got an MDF boot-floor with straps passed through it around the sub.
works a treat
Also need to secure mine somehow, it's heavy and doesn't move about much (sits on the righ tof the boot above spare wheel) but it's quite a weight not to be secured in an accident.
Whats the best way to secure it wihtout causing too much bother getting at the spare? tah
  Listerine & Poledo
My MDF floor is a 2-piece design, I can lift out the piece over the spare wheel without moving the sub at all. If you keep the margins tight then carpetting will keep both pieces together, or get some clips to keep things in place.
Ah thats a great idea! Do you have any pics of it? thanks
  Listerine & Poledo
not right now, sorry.
Earliest would be over the weekend, dont get home before the night closes in.
It's not a tough one tho.
use boot carpet as a template, cut using jigsaw,
slice into sections,
cut out strap holes on section you want for the sub.
Carpet both sections
then fit, either with out without original carpet. If with the original carpets you can velcro the mdf to the carpet if you like?
  PH1 iceburg
I started with industrial velcro, worked well. I ended up making a falsse floor cutting around the base of the box and it never moved. Wood only cost about a fiver from b&Q, just asked for any big bits of scrap.
Sounds great, thtas prob how i'll go about it. thanks
  S4, Tamora, Conti GT
Velcro, or a very thick double sided tape, but this doesnt work if you intend on taking sub in and out of the car, another option would be get a twin sub and the extra weight keeps the box in place.
