Throttle Sensors, what and where?
So the 182 has flashed up a couple of fault codes on diagnostics. There are 2 throttle position codes that have flashed up.
I was wondering, in the past i have cleared the code and it has been fine for a few hundred miles. Then once i have put the cruise control on, the eml comes back on with the same code.
Could this be the throttle body? Or are there any other sensors that could be throwing this up?
  E36 328i
I think the pedal has a sensor on it too. I'd get it plugged in and read by someone who knows what to look for though tbh.
  LY 172
What codes? Been having similar problems.
Removed the throttle body, cleaned with WD-40 and greased the butterfly valve shaft a little. Unclipped the throttle pedal plug. Hoverd up any dust. And the cars been fine since.
