trackday killed the engine - ideas please
  53 Clio's & counting
gotta be flywheel mate, funny enough just had this on a touraeg at work
so you can make the flywheel move without the engine moving? Most def flywheel
be interesting to see what you have done, Drhouser did that and it ended up wrecking his bottom end :(
  TVR Cerbera
wrecked bottom end? how and what damage? don't need that. it had a new bottom end 18 months ago at GDI for a spun con rod bearing. Grrrr
the shock of it put pressure on the crack at it span a shell iirc
I already know i can move it about, with a screwdriver on the ring gear
Yup if you can mive it that much i bet a bolts come undone, i wouldn't risk running it though fella, as i will say its wrecked the flywheel, but if its dropped a bolt it will still be in there somewhere!
