uneven wear on rear tyres
  E92 M3
i am going to buy 182 and the seller says the mot brought up that the rear tyres have uneven wear, do i need to worry about it or not
  ITB'd MK1
will either be incorrect tyre pressure, or just normal wear on the inner edge (being slightly more than the outer)
If he's told you about it then i'd be less worried really, unless the wear is singificantly uneven i wouldn't panic
Check for uneven wear?
Could be under or over inflated tyres, could be the tracking is out, but as danny says, wouldnt worry me too much tbh.
  172
so more wear on the inside than outside of the rear tyres is normal then? By more wear, i mean on mine i got 5mm outside, 3mm inside...not like tyres are 8mm outside and bald on the inside lol!
