As some of you know (or maybe not) the Clio engine has the most basic form of Valve Timing.
Basically the engine runs one cam profile for smooth idling and at 1,500rpm the profile switches to the other profile.
Ive been thinking, would it not be possible to change the low rpm cam profile to give better power to say 4,500rpm, and then switch to a more advanced profile from 4,500 to about 7,500.
Would this be possible with the SMT6?, ie change the cams, then program the piggyback chip to switch profiles at 4,500rpm instead of 1,500rpm.
Would getting this right be a very complicated affair since the VVT on the Clio only works on the inlet cam, while the exhaust cam uses the same profile throughout the rev range...
Might make the car more drivable at low rpm if it had cams designed for low rpm power.
Okay, Ill stop thinking now...my head is starting to hurt a little...I need some coffee
