Windscreen Washers
  Clio
Hi I'm new to the forum but just recently bought an 02 1.2 Dynamique with only 49k.
I have an issue with the washers. If I pull the stalk to operate the front washers it operates the back, not the front. If I use the rear washer the rear works as it should.
Can anyone help please?
  PH2 172
The rubber piston that shoots back & forth between the spouts is jammed.
Replace the pump, about £7.50 on eBay, you`ll get a good one eventually.
Or you can fath about shaving the piston on the one you have.
  172 Turbo
Is there a decent one available Steve? I went to Renault and they wanted £50!
  PH2 172
The one`s I ordered are out of stock.
To be honest quality is a bit hit & miss.
The one I fitted to my car 12 months ago is fine, but the spare I had jammed within 24 hours when I used it on somebody else`s car not long ago.
They are common to Renault & PSA, so this one would be OK,
http://www.ebay.co.uk/itm/For-Peuge...722789?hash=item4d0bc1a8a5:g:NhUAAOSwkShY91YW
IF ECP or GSF do them for a sensible price, it would makes returns easier if there is a problem.
