Xenons
Car  RENAULT CLIO 1.5DCI
I want to put the 172 xeons lights on my dci but have been told this will fail mot due to me not having the washers in my bumper for the lights is this correct?
many thanks
Joe
Re: Xeons
*xenons
Technically thats correct, but it will all depend on the MOT tester at the end of the day. Have a search around there are people who have said their car has passed without them.
So long as they are well adjusted you "should" be fine.....
Re: Xeons
Is it not the case that they wouldn't fail as there are no washers to test in the first place? You can't test (and thus fail something) that isn't there?
Re: Xeons
The best i can tell is:
http://www.motinfo.gov.uk/htdocs/index.htm - "Inspection Manual for Classes 3, 4, 5 and 7 Vehicles"
Section 1.7: Headlamps:
Where HID or LED dipped beam headlamps are fitted, switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
Re: Xeons
I would just fit them anyway. My headlight washers never worked, I disconnected them because they leaked all the time.
Never had any issues across 2 mots.
Re: Xeons
States check operation of ANY levelling and cleaning devices. If there aren't any, then there's none to be tested. We still build new MINI's with xenons without washers.
As said if not present it is not testable.
Had our clios pass 3 mots with them and no washers. It is only a requirement for a new vehicle to be registered and once it's been registered the "if it's there test it" rule
