Self adisive grip tape
Car  Clio 197
Hi does anyone no where i can get wide sheets of grip tape from for my foot wells wide enough to go across each well.
Thanks Nick
the only thing is, with each footwell not being perfectly flat, id be unsure of how plyable it will be to work into each crease and dip and still look presentable.
i used a big roll i purchased from Halfords and just applied a few strips in the places that seemed more feasable for people getting in/out of the car.
(assuming this is for a stripped out car?)
Yeah was looking at skate board tape but was not wide enough to go all the way across so ill try halfords to see what they have and yes is stripped out.
Thanks
Use skateboard grip tape i have and it worked a treat on a uneven floor (with a heat gun) 2 lengths side by side and the floor well is covered here's a pic of mine before i removed the support bar and fully stripped it again.
Good thing about a decent quality skateboard grip tape is its quite durable even with wet shoes on it etc, as its designed for that.
Need to order some but not near the car to measure up. Could you tell me how many 9" x 33" lengths (common order length) you used, as your coverage is good? Ta.
I've been using board tape for years as car mats in stripped cars, for a neater/more o/e sort of finish I just use the original mats as a template and chop out actual mat shaped cutouts of the tape :)
I'll be heading over the garage in a hour so can measure the floor area of where i had it covered previously and post back.
From memory i bought 3x 9"x33" in a (uncut) continuous strip and still had loads spare.
Just measured and it came in around 25" in length and 2x 9" strips side by side.
Hey thanks allot for doing that, wasn't sure if I could get away with 3 lengths then, seemed so and I can put the scraps on the passenger side .... Ta!
