Xenons
Car  Clio PH2 K4M
Can you fit the clio sport xenons clusters into a non sport, is it a straight swap or is there more wiring to do? Ta
If you buy some 182/172 xenon lights then replacing them should be straight forward. You will possibly need to swap the adjuster cover from your old lights on to the new one if the connector doesnt fit, this will be obvious when you have the lights infornt of you.
You will also need the self levelling mechanism on the rear axle ideally - this could be an mot fail possibly if you dont.
But yeah should be easy to just swap the lights.
Yep. Oh and if you find some, ffs don't let the seller post them to you. They WILL break.
