Used, 4 hole I think, bought them with my throttle bodies. Instantly decided against themWhat sliders are in them mate ? And are they in new condition or used lol ?
I'll grab some photos of them tomorrow if you like, where are you located?
What slider kit do you run on your front windows ?
Have you glued the front windows in round the seems ?
Thanks mate to be honest I have a few other parts i need to buy before the window plus the bill for the roll cage has come through as wellUsed, 4 hole I think, bought them with my throttle bodies. Instantly decided against them :smiley:
I see I am with you.They're not lockable as such, but they are lockable in the fact that there are tiny nylon lock nuts on the inside and you can't undo them or open them from the outside.
The window is just a big square hole rather than four holes, and the slider is what slides across to cover it.
I haven't glued them in no. They are held into position by the original bolt which holds the glass in place. They won't move for s**t now. And I've got foam edging around the edges to stop it from wobbling.
No leaks either as the actual hole is covered by the window scoop.
That's pretty good I thought you had to glue round the window leave it for a while and then it fall out haha. Stupid question time because I haven't looked at the window mech yet where do the screws screw in because I have cm composite fibre glass doors and they are empty inside that's why I thought I might have to glue them in place
Ok mate thank you very much I shall have a little look over the weekend see what I can find/ break hahaWhen you take the normal door card off mate it's easy to see. It's just the bolt for the support bracket for the glass. I've taken the mechanism and brackets out, just put the bolt through the hole in the door like normal and the plastic is tightly sitting on top of it.
