thin spacers with centerring?
Don't think I've seen any for any car that are hubcentric below around 8mm. Why don't they do them?
Would 5mm even make a noticeable difference? I went with 10mm stub spacers on the rear and could probably get another 10 easily
Depends what wheels you've got and what the offset is to start with.
I had 10mm hub spacers on the rear with cup turinis and found it too much so dropped down to 5mm.
this, I run a 300mm brake kit with alu bells, ET37 wheels and 10mm spacers.
will be running a rollcentre kit soon (been in the shed for a while) and that increases track a bit aswell, so wanted to decrease spacer to the absolute minimum.
might check clearance with some washers first to determine spacer thickness.
