Flob
Hi All,
I need to do a number of jobs on my car soon (182). Cambelt + Aux belt and clutch are the bare minimum. I figure its just easier to pull the engine and box out (hoping to drop them both out through the bottom on the subframe if thats possible?). Will be buying a dephaser, water pump, belt kit from somewhere.
While I'm there I intend to also so rack bushes + inner/outer track rod ends, engine and gearbox mounts. Then give the engine and bay a really good clean.
What else would people advise doing?
Ive found this timing belt kit: https://www.ebay.co.uk/itm/Genuine-...h=item41913c4a25:g:4L8AAOSwrklVcBjD:rk:2:pf:0 - is this a good choice? Any one know of a cheaper kit, or a kit that comes with the aux belt+ tensioner too?
What clutch kit do people recommend? Seen LUK mentioned a few times, have also used Sachs kits on other cars with good results.
@bloke has mentioned in other threads I've read that it maybe a good idea to pull wiring loom out for inspection. What normally fails? Connector corrosion or the wiring? Is un-taping it all really the best way to go?
Any advice would be great, happy to spend circa £1000 on parts which I think could go a long way (or far enough at least).
Rob,
Rob,
