Spacers and shims
DomP182
  ph1 172, Arctic182
I think I'm finally going to bite the bullet and get some spacers to throw my cup off set turinis out a bit. I think I've decided on 15mm hubcentric fronts and 10mm rear hub spacers for the rear but I cant decide whether to get them with a bit of camber to go with the 1.5° I'm going to put on the front.
  monaco 172
Might be worth getting it on a decent alignment machine before hand to see how much camber and toe you've already got on the back they always seem to be out on the back anyway
DomP182
  ph1 172, Arctic182
I did think that, do most places give you a read out with no adjustment for free so I can order what's needed before going back to get it sorted?
  monaco 172
Yeh, even kwick fit and the likes do it, just be prepared for the hard sell after theyve given you your free check
Crayola
If you've still got the original rear beam bushes in then get them sorted too. Otherwise, you'll have one side that sits's lower/higher or more right/left and it will infuriate you 😂
