MK5 Golf - Spares or Repairs **ebay**
Date tested6 August 2020
FAIL
View test certificate
Mileage143,625 miles
MOT test number6687 4250 3236
Test location
View test location
Do not drive until repaired (dangerous defects):
  • Rear Brake disc in such a condition that it is seriously weakened (1.1.14 (a) (ii))
  • Rear Brake pad(s) less than 1.5 mm thick (1.1.13 (a) (ii))
  • Front Brake disc in such a condition that it is seriously weakened (1.1.14 (a) (ii))
Repair immediately (major defects):
  • Anti-lock braking system warning lamp indicates an ABS fault (1.6 (b))
  • Engine MIL inoperative or indicates a malfunction (8.2.2.2 (g))
  • Electronic power steering warning lamp indicates a system malfunction (2.6 (a))
  • Offside Front Position lamp not working (4.2.1 (a) (ii))
  • Headlamp aim projected beam image is obviously incorrect both (4.1.2 (c))
  • Headlamp has a product on the lens so that the light output is severely reduced both heavily scratched discoloured (4.1.4 (b))
  • Registration plate lamp inoperative in the case of a single lamp or all lamps (4.7.1 (b) (ii))
  • Nearside Front Body panel damaged and likely to cause injury wing / bumper damaged sharp edges (6.2.1 (a) (i))
  • Windscreen washer not working (3.5 (a))
  • Exhaust diesel particulate filter shows evidence of tampering. (8.2.2.1 (c))
  • Rear Service brake excessively fluctuating both sides (1.2.1 (e))
Repair as soon as possible (minor defects):
  • Offside Front Anti-roll bar linkage ball joint dust cover severely deteriorated (5.3.4 (b) (i))
Monitor and repair if necessary (advisories):
  • lights fault warning illuminated
  • h i d headlamp conversion / no washers
  • Front Registration plate deteriorated but not likely to be misread (0.1 (b))
  • trims and covers fitted
  • Offside Front Outer Tyre worn close to legal limit/worn on edge (5.2.3 (e))
  • Exhaust has a minor leak of exhaust gases (6.1.2 (a))
  • exhaust heat shield loose
  • Rear Sub-frame corroded but not seriously weakened (5.3.3 (b) (i))
  • Offside Front Service brake fluctuating, but not excessively (1.2.1 (e))
What are defects and advisories?
You would need to do the dangerour and major defects before it'll pass a test.
Fair amount of work though, if it needs a new rack, then I'm sure you'll need a new subframe as the mountings changed and you can only buy the revised version now? Plus all the fixing bolts are 180 stretched and the bolt kit is around £60 if I remember correctly.
