New day….new leak
Hi all,
My Clio 182 has developed an oil leak from the front passenger side, specifically it’s apparently coming from this silver cylinder (see photo).
Any idea what this is?
Many thanks,
D
I took it into Diamond Motors, it needed a re gas but appears to be holding pressure and is still blowing icy cold 2 months later.
Does the air con system run a separate reservoir?
This is the complete system under the bonnet.
Mine is leaking from the seal on top of the dryer and a little bit from the pressure sensor. Then running down the pipe and dripping from exactly the same place as yours.
It's going into a specialist in October.
