Thanks. I tried to get to the injector earlier but the fuel rail is in the way and didn't have to much time to look to see how I can remove itSwap the plugs around and see if the misfire follows.
If it stays on cylinder 3 then you can swap the injectors round to see if that’s the issue.
If it still stays on 3 then coil pack.
I hope notYeah if its anything like the non-turbo d4f it's an inlet off job.
