yozza decat
  53' 172 Cup
does the YS decat for 172 Cup come with new bolts and gasket etc.?????
really thinking about getting one - is the whole issue with the emmisions light coming on a big problem (some ppl say it does sum say it doesnt..??)
whether its a sports cat or a decat it may or may not come on ...... i have fred's no. if you require it ....
hmmmm...so there is no way of making sure it stays off? thats wierd. does it not actually affect the car driving with it on?? i will still prob get one (is it really 5-6bhp gain tho?!)
It's not a problem if the light comes on, I think I'm right in saying that with a 172 you are less likely to have a problem.
My emission light came on 8 months after fitting my de-cat, was easy enough to reset with a £30 scan tool off ebay. Hasn't come on since.
Mat...whats this scan tool you speak of, sounds pretty smart...can it reset the ECU??
The U480 Trouble Code Reader is a scanner for real-time automotive diagnosis based on the OBD 2 protocol with added CAN-BUS compatibility. It offers many years of reliable use with its robust housing and solid construction. By simply plugging it into your vehicles diagnostic socket, you will be able to read all trouble codes related to the "Check Engine Light" and identify the code by consulting the manual. Reset the trouble light and reset OBD 2 Monitor Status. Also retrieves the VIN (vehicle identification number) on supported vehicles.
There's one for sale here;
http://cgi.ebay.co.uk/U480-CAN-BUS-...ryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
will that be able to reset air bag light faults??
it'll just flash all fault lights off the system. so if its an underlying fault the light will keep coming back on, but if the problem has been rectified and it isnt a self-testing system then once you've knocked it off your done.
i doubt it will be able to knock off the light from something like if you had removed your steering wheel airbag for instance.
does it come with the different adaptors for different cars? i thought they changed with the makes..?! seems a nice little tool! diagnostic kits cost thousands i thought!
