FAO FRED OR ANYONE!! :)
Car  BMW F31
had a slight problem with the car coming back from trax, garage has the car, i thought it might be driveshaft, they think its gearbox related, possibly the diff or bearing.
is the diff or bearing expensive??
would i be best getting a new box if its the diff? if so what boxes fit? e.g 1.6 megane box? 1.4 16v clio box??
cheers guys :)
You cna use the box ratios won't be that different just got to check you have the speedo sensor in the gearbox if you need it.
JB1 on a 16 16V doens't sound right though they should use the JB3 maybe its a 1.4 16V (engine look the same) as they use the jb1 boxes.
