Climate Control Sensor fan?
ati
Car  Clio Dynamique
heloo all
there was humming noise coming from the light and sun roff compartment after much research and emails, i found out it was the fan for the climate control sensor that is making all that humming.
anyway i took it all out, i took the surround offf and took everything apart, i basicaly got the fan is the small black little thing by its self .
i still cant figure out how it make the noise i took it all out and than just plugged the electric back so it was just the fan and the bit that hold it and i can really hear it.
so do i have to replace just the small black fan by its self or the entire the mechanism that holds the sensor and fan?
thanks
you took yours all apart yet?
or if you have you ubnsure what part needs replacing
Cant you swap it out for the late 182 noiseless nipple?
if someone has a part number...
havent heard or seen that before, any pics or part number anyone
82 00 093 290 TEMP. SENSOR 7.42 ---3 x 1
You mean after I told you lol ;).
yep thanks to bmh, for letting me know all about this,
can someone tell me about this noiseless late 182 noiseless nipple?
whats the difference and price wise as well?
thanks
p.s bmh catch me msn ifyou could mate i,mon now
no probs, wanted to ask ya couple of things about car audio and so forth but no worries if cant.
could you let meknow the difference between this silent one and normal one i have here?
bloody renault quoted me £18.62 for the fan, bunch of idiots these guys here
is it possible to swap it out for the noiseless one and anyone know the difference?
and the price of em? or do i have to get the fan one for the 53 plate dynamique?
are they all standard fit?
thanks
No idea on the noiseless one, haven't seen it before. afaik they all use fans so this is new to me. Would have to dig my reciept out but i'm sure it wasn't £18 might be though I can't remember.
Can fire away on msn no probs, i'm on usually 5-6ish and 9-10ish in the evening.
hi bmh
is this the part no for the fan version or noiseless one?
i cant view the video, whats the part number for the fan anyone, someone mentioned is on the clip?
thanks
hi tom
i havent heard of this or came across it, whats the difference between the two and would it fit on other clios?
Remove the fan use and grease up the shaft and small brass plain bearing.
Its relatively a simple job, once you've done it once you can make it a 6 monthly maintenance task. Takes around 5-10minutes.
hi tom
someone will hopefully post a pic, late 2004 onwards models use a nipple.
thanks for the tip Ralph Wiggum
does that quieten it down ?
Yeah mine makes a very silent put put noise. Inaudible when the engines running.
Don't last forever. I have also seen the nipple type Tom is on about.
Must be able to straight swap then?
hi
can you tell me where you got that nibble type?
have you got a pic there handy and how much you got it from?
have you swap it as well?
the humming def annoying, renault quoted me £21.60, how the hell is everyone getting it for £7+?
is there any number or suppliers anyone have handy?
i,m intersted in this silent version, i dont wanna do this every year?
what car type does it come from?
any info would be great :)
that sounds abour right, managed to get the video, is even £7 on there?
does it really make a difference with a new one, howabout getting one from the salavge yard?
