HID Xenon Converstion Kit
Car  Blueprinted 172 Ph1
Can anyone recommend a good HID conversion kit for a 172 Ph1?
And what temp should I go for? eg 4500k, 5000k etc
Thanks
I got a kit of ebay, £40 6000k, looks perfect.
Not the best pic to show them off im afraid.
All those kits are overpriced and the 1st 4 are wrong fitment. You need HB3/9005 bulb type.
The bottom link is the same seller i got mine from, but the link i put higher up the page will only cost you £40. But you must specify what fitment and colour temperature you need.
Do you think I should get the "BIXENON" kit or is it not really worth it? Have you got HID light for both dipped and main beam?
To be honest mate I would only have them for dipped as I have on mine got a kit from ebay seller doesn't seem to be on there anymore tho but had no problems what so ever, I went for 6k looks mint.
would this be the same kit for my mk2ph2 clio? 04 reg.
Only if you have projector style headlights otherwise you'll probo dazzel everyone.
i've got them in the dipped and main beam of the polo head lights
i also put osram silver stars in the clio
imho i think osram make just slightly better lamps than phillips
oh i see, erm... projector style? i just know i put a bulb in? lol..
lol, projector style headlights have a solid glass projector lense rather than the usual reflector.
your mk2ph2 won't have projectors unless the lights have been changed to angel eyes etc.
unless you swap the healdight cluster for an angel eye set (bearing in mind you'll probs lose the motorised adjustment) the best you can hope for is one of the upgrade bulbs that are just a direct swap - contain xenon gas but don't even come close to the performance of a HID xenon headlight.
