What i want to do is have my 360 on two screens in the house. As the bluetooth controllers have good range i want to leave the xbox in my room but for example play it in the living rooom! I am sure this is possible but no idea how! Anyone got any ideas?
If I'm in my room playing on the 360 then walk out the room with the controller in my hand it disconnects and the "please reconnect controller" message comes up
well i have done a few tests and my contoller works in the other room to the xbox, thought about cables but cant find one that would work!!! and would be mega expensive
I used to do this in a little one-bed flat where the rooms were next to each other. Worked OK. Just used a massively long composite lead (red, white and yellow phonos) and a video amplifier box to boost and split the signal to multiple feeds.
Composite? Are you mad, quality is s**t! Depending on how far the room is you want to get the VGA Cable for Xbox then put it into a splitter with 2 VGa's out one to each screen. Bearing in mind it has VGA's on both. If there LCD's they should!
