LOL , some of the happy customers quotes from the add
A pleasure to do business with and very easy installation 100% Great Seller. Quick Service. Part made my 1 Lt AX go like a 1.4 Lt. Installed on mondeo 1.8td greatly improved pulling power below 2500rpm impressed Noticed a difference in 1,2,3gears to many police for top end,cheers mate Very quick delivery, big improvements on performance, would recommend A++++ very speedy delivery AWSOME piece of kit makes a difference Fitted to escort gti and xr2i, great results. very pleased. quick delivery,A++++ Quick delivery, simple to install extra power on a T Sport, very pleased excellent gains in power, many thanks, professional ebayer Fitted to 1994 imported Prelude 2.2SI - and it works. Improved torque Excellent gains in power, many thanks, professional ebayer Brilliant, Can`t believe it actually works, Thanks A+++++ Thanks for item it works really well, marked improvement in car cheers Mondeo V6 is approx 5mph faster at the 1/4 mile mark. V. easy to fit. Fast delivery, good product, my car is now even nicer, faster, easier to drive Great item no problems fitted it to my sons fiesta goes a lot better now 13% more torque,on the rollers power is up, 190.1bhp from 182.9bhp all for £6! Great product, cant believe it works and much cheaper than others on ebay! Recommended product, made a big difference, recommended seller A++++++++++++ 100% Great Seller. Quick Service. Part made my 1 Lt AX go like a 1.4 Lt. It arrived quickly and works a treat on my golf gti thanks highly recommended fitted this magic device!!!!!!WOW!!!!!!!!!!!!!!!!! transformed the mazda mx3v6 my civic has got back all the speed it lost when i put 17's on. it's awesome!!!! fast delivery, well built, better than everything else out there. cheers... your product was great car now O-60 IN 4.2 SEC 2seconds quicker will bid again quick delivery, fitted it within mins, worked a treat, cheers mate EXCELLENT SERVICE AND MONEY TO PERFORMANCE EXCEPTIONAL! ++++++ goods arrived on time as promised does what its says on the tin!!!!! super fast delivery and as described,fantastic,thank you very much ++++++++ helpful. prompt delivery. device works well very big difference to my 1.2 clio! you'd think it was a 1.4 A+ Item received. very pleased with the outcome THANKYOU ;-) ;-) Good Improvement...Thanks!!! Quick Arrival as well!
my bro fitted one to his mk2 golf!, it made it spit white smoke for and tick over at 3000rpm!!! hahaah its just a single resister which costs less then a penny! we paid 50p for his ahah
oh my god, this is basically like having a broken coolant temp sensor, the car is fooled into thinking its cold, therefore adding more fuel, though why do you need more fuel being put in? will do more damage than good imo, i would not put that anywhere near my car!!
"oh my god, this is basically like having a broken coolant temp sensor, the car is fooled into thinking its cold, therefore adding more fuel, though why do you need more fuel being put in? will do more damage than good imo, i would not put that anywhere near my car!!"
If he has a RR and will do a normal run then a resistor run would be quite good to see the results but I'd never let one of these touch my cars!!! lol!
why not just run your coolent sensor through a varible resistor so you can turn it off so that coolent temperature sensor can work fully, of you can fool it
I have one to, needed to up-grade brakes and suspension due to power they produce. Still couldnt put the power down, the Clio is not built for such power leave well alone............
If this item works by fooling the ECU into overfueling then you will be getting unburnt fuel being taken out of the cylinder and passing through your HOT exhaust system. The unburnt fuel will then ignite in the exhaust system and will probably destroy your cat. DON'T DO IT. :nono:
