My stop light came on and i had my handbrake light flicker on and off repeatedly every time i cornered... turns out it was my pads, replaced them and hasnt happened since, not sure if there is a sensor on the brakes that alerts you too it or something, but as i say, problem solved, hope this helps
As said above, normally indicates low brake fluid. This could be from it leaking or low pads. Any sign of much fluid around the fluid reservoir?
Well Ive had to top it up twice in 2 months with a full (small) bottle each time. The guy in Halfords did say that is unusual as you would only top it up every year or so.
Think I just need to book it into a garage tbh and get it checked over.
Will have to wait till new year now though
take is easy on the roads for the time being then tyssen bad times for iffy brakes![]()
means your pads are low...
waaaaaaaaaaaaaa body foooooorrrmmm......body form for youuuuu
