heat shield knocking!
Car  172 Cup
I know this happens to alot of you with aftermarket exhausts, tried bending it but its being stubborn, what do you think best thing to do is?
Im guessing if he's tried bending it he can see it sat on the exhaust Juan.
New heatshield is best fix, has it sheared away at one of the bolts and dropped?
Mine ended up being the lambda sensor touching the hole on the heatshield that it goes into. I just made the hole bigger.
do you have an aftermarket???
mines was hanging off and rattling like hell at the backbox...
just got a washer that covered the enlarged hole...and stuck it over..
just got a washer that covered the enlarged hole...and stuck it over..:approve:
same here larger washeres mine perished and fell over the washers so just replaced with beger washers :approve:
