Coolant - Now or Service?
Car  200 Gordini
Going to be getting the 182 serivced in the next month or so.
Its just turned 4 years old and needs the coolant changing.
My question is, is this done in the service or shall i do it now?
I think 4 years is just a safty precaution/recommended time tbh.. like the cam + aux. If its dirty or runs out then it will cause damage right.
Im curious if i should wait until i have my service or go to GSF later? + if its even done in the service..
starts to loose its antifreeze properties and anti corrosion properties . . . . do i need to say what both of those can do to the engine lol
right type? coolants coolant even the best tell you that
do the lot yourself and do everything!
yes and no really, they say your supposed to use OAT type personally dont think it makes a massive diff either but id use whats recommended its not much more expensive.
u need to ask for the coolant to be changed aswel as brake fluid, they are both 4 years 72k.
coolant is type D
brake fluid is dot 4
Like they said, Type D Renault/Elf coolant (mixed with demineralized water 50%) alogn with brake fluid change, both are really important.
