Drop me a pm with your address and il send you a couple!! They cost 0.025p per resistor!
The ones you get from capital searing etc are expensive as you get a fancy plug with it. Plinking a resistor in the plug does the same thing!
When you got the recaros in a trophy, do they just have resisters in the plug, or do the renault ones have a connection on the seat?
Always wondered. Thanks, Sam!
Got mine from Capital seating.
Me too![]()
I've used the maplin resistor's and they didn't work i used a professional garage to fit my recaro's aswell so no back street jobby but luckily i ordered a second pair of resistor's from capital seating fitted them and they worked a treat i didn't even have to get the airbag's reset either.
Imo you only get what you pay for.
Me too![]()
I'm sorry but that's b****cks! You don't get what you pay for. Sometimes when you put the rresistor in it doesn't make contact enough as the legs are about 0.1mm smaller then the plug. To make sure they are making good connection you can snip a bit of the resistor leg and stuff it in after putting the resistor in to pack it out and ensure it won't move around.
A resistor is a resistor, capital seating don't use special ones! They just provide you with a nice fancy connector.
I used normal 3 ohm resistors in my steering wheel to turn off the airbag light , the light didn't go off though to start with as the legs of the resistor were again too small, so snipped a bit of the leg and used that to help pack it out and a bit of insulation tape to help it too. I did gregg's on here too and he has never had a problem.
A bad workmen always blames his tools/parts
(no offence ment by the way)
