best place to drill firewall?
Car  clio 1.9 Tdi
hi, i was wondering where the best place to drill through the firewall on a MkII clio. any help greatly appreciated. pictures would be a bonus! thanks
I've found the wire on either side but can see the grommet. i loose it in the engine behind the a tube with wires in it next to the block ware the suspension is.
if you look inside the car under the glove box you'll see it. You'll have to thread it from the inside up the sound deadening behind the power streering fluid reservoir. It will make it easier to remove the reservoir first to give better access. Still not done mine yet. need weather to warm a little :)
yeah i followed it to behind the reservoir, i will remove it as you said, thanks for your help!
