Reverse lights
Car  Petrol Blue Clio182FF
Noticed last night that neither of my reverse lights were working. Any ideas what this could be? I have had a look at both bulbs (only through the light cluster though) and they both look fine with no breaks in the filaments.
Any ideas?
I would give the connectors a check as the tend to corrode, if thats not the problem then the above may be.
I believe that one cluster gets the feed from the other, so if the main cluster connector is bad the other won't work .
Ah, wired in series then. I'll definately give the connectors a check after work tomorrow. Cheers.
