Vibration problem.....
Car  Clio Rs ph1/182 cup
hi mates...........I've got a huge problem ...
when I accelerate smooth/floor the car vibrates a lot.....and i don't know what could be ....Ican tell you that the problem isn't caused by the wheels...
what do you think about it ?
check your drivers side driveshaft for play. its a common fault on the ph1 to break up inside the inner cv.
jack up just the drivers wheel, put in first and see if the wheel rotates left or right. a tiny bit of play is fine. and more its likely to be the cv joint.
CV is the constent volosicity joint. the ends of the driveshaft( with the rubber boot on)
the bearing inside can break up and give play. and when driving its not central so give a bad vibration.
hope this help
