Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
right hose is top engine outlet (at stat) to rad top hose
left hand hose looks like it's been cut as the lower section of hoses is a complex series in one piece. The part that's there goes from the bulkhead to the outlet under the temp sensor.
Ones bottom of rad to engine (next to the oil filter) the others top of rad to water pump, The others headertank pipe, hope this helps. The one at bottom of rad is a bugger to fit!
