washers!
Same place as the windscreen, but your cup won't have them?
got hid lights and the washers worked on them when i got the car bout a month ago. filled the normal place and still nothing, it sounds like its trying to squirt water but nothing comes out!
Those flat square things on the bumper below the lights......aren't washers. They are blanks.
It may well be a Cup with washers retro fitted, but if I was you I'd take them off again.
You buy a Cup for the weight save and tbh I think they are useless.
All they do is streak the bonnet and make you fill the bottle sooner.
they are not flat and square, they more like a cone shape and iv had water squirting out them b4!
Just means that someone has decided they wanted to have the washers on the car. (Pointless, but fair enough).
Anyway, they come from the same tank as the windscreen washer fluid.
Because you have all the parts from a normal 172. So either you don't have a Cup or someone has made yours into a normal 172..
Do your wheels look like this..
You might want to check your insurance to.
If I was an assesor and turned up to that and you had it down as a cup i wouldn't pay.
Ok. The hoses have probably come off or there's a lump of snot stuck in the hose and you need to change your profile to 172.
End thread.
Well have you got it on your insurance as a cup?
Cos if you have and it's not, it's not insured.
