the one i used you could only see if you had your head in the footwell looking up, you could probably see it if you took the passenger air vent out so to speak
Not just use the hole the bonnet release cable uses?
you don't have to take the vent out it just gives you an idea where the grommet is
Where the isboar bolts are
Isobar has been removed from the car :rasp: ill try find a bolt though and just bolt that back on minus the bar!
