rear of the car ???
Car  1.2 clio
hi ive done a conversion on a 1.2 and put a 172 engine in the car ive got 172 front running gear rolling on 1.2 rear. i was looking to get coilovers but will the 172 coils fit the rear of the 1.2 axle. most ive looked at are shocks and springs for the rear but will this fit cheers mark
depends on the building year, if you have the older ones with proper teeth-rings you can use some kangoo ones i think. the newer ones have special abs rings need replacing the hole abs/esp unit and sensors then.
