6500_5404 LAUNCH CONTROL question
Car  A dieppe product
I have installed this on my car and car revs normally to 7k,no stop at 4500,I have write ecu to 6500_5404 launch control and then I have write cal to 6500_5404.I think I have done something wrong maybe write cal to 6500_5404 it's not necesary and I only have to write ecu to 6500_5404 launch control,can somebody help me?
Car needs to be at full warm up, that is at work temperature. If it is cold/not warm enough it will rev normal. Also remember this only works at a stand still or going very slowly, it switches back to the normal rev limiter at certain speed (don't know which). I also have it installed and never have used it LOL, but goog to know it is there ;-P
You need to upload 6500_5404 launch control only, it has the map already on it, if you use the other you are effectively taking the launch control off
I had the same issue's and after a quick mail to henk found out the correct callobration to use is the launch control only
