Hazard Warning Switch and Replacing Headlight Bulbs
Car  Racing Blue 182 Cup
New to Clios so was wondering on my 182 Cup should the 'Red Triangle' on the hazard light switch always be illuminated even with the lights not on? Also whats the easiest way to change the headlight bulbs as there seems to be very little room to access them?
is it a cup? or a cup packed 182? Coz if it has xenons its a bumper off job, if its standard headlamps its a bit of a fiddle due to lack of space but easily do-able!
Cup so standard lights. So a tight squeeze then! What about the hazard warning light switch?
Yea just a very tight squeeze, can be achieved with a few minutes and some swearing i've found.
No idea about your hazard warning light though bud, pretty sure it shouldn't stay in all the time, sounds like a short somewhere?
Just double checked and my hazard warning light is always dimly illuminated when the car is on, flashed brightly when you actually use it, so i guess its normal!
It's a f**king nightmare on the driver's side due to the AC pipes. Definitely not bumper-off, might well be worth doing if you don't have small hands. s**t design.
