Trumpets for fog light surrounds
mikes86
Car  182 track **** & MX5
Just wondering if anybody has successfully found a trumpet (air ram feed) to fit inside the oval PH2 fog light surrounds, if so, what shape/size did you use?
the closest thing I found was a sub box port. It had to be trimmed a little to fit nicely but remove the fog surround to get it fitted nice, then refit the fog surround and it looked pretty good
I have one on mine, taking it off today to put the fog light back though. It was on the car when i bought it.
[/IMG]
It had to be secured in place using zip ties but fits in perfectly.
Thats exactly what i'm talking about! Does it sit flush, because the surround is slightly curved?
Well the lip is bigger than the fog hole so the lip rests against the the fog surround. only a little bit though. at the back of the trumpet there are holes either side which i have used to put zip ties through and connect with the cold air feed going up to the air box!
Didnt manage to change it over today but itll be in the sale section soon if you're interested;)...
That looks great bondy, have you got any close up photos of one of them? Also what did you use to bond them in? I assume the trumpets are metal?
I made my own by sacrificing my fog lights lol...
Before paint
Diffrent car I understand but can easily be done on a Clio :)
Here's the dims and web address for the ones I purchased on eBay. I had to bond them in but they've been in for 6 months now.
Outer Diameter Top of the trumpet: 110mm
Inner Diameter Top of the Trumpet: 80mm
Outer Diameter Bottom of the Trumpet: 66mm
Fancy making and selling some? :)
With the trumpets on eBay do you need any cover? like a cloth so no leaves or rocks go up the feed?
