Hazard light button ??
Car  Monaco 172 Ph2
I see people on here always lloking for them,
however waht is the symtoms of this not working ???
I only ask as my hazards dont work, but i thought this was due to the previous owner fitting a laserline alarm
and it had subsuquently knocked them off as it uses them ???
Or is it just the alarm causing this and not a knackered button ??
How can i check - Ta.
Make sure the button is plugged in?
Faulty ones make them flash non stop so people just unplug them till they get a new one or just leave them unplugged!
Might sound daft but where do i look ??? would i be right in assuming behind the actual switch lol - if so easiest way just taking stereo out ??
The switch has a plug on the back for connection, the little rectangle plate which the hazard switch, lock button and rear screen de-mist button should just pull off if you slot something in at the side and pry it out.
