Has anyone fitted Wossner valves? It states that they need to be fitted with uprated valve springs due to an altered collet height, I’m only running the standard 182 cams so I’m unsure if I can fit uprated springs (cat cams springs) to a standard camshaft?
Will they be to stiff? Or will they ‘wear’ the lobes on the cams??
Anyone shed any light!?????
