Repair or replace Clio 172
  Clio 200FF
Hi all, don’t really post much, more of a search button person but after some advice.
I have a Clio 172 for the last four years, just recently had its MOT and came back with some advisory’s as to be expected. Working out how much it would cost to fix and replace, along with belts due later this year. The costs are comming close to the value of the car and I’m unsure what to do? Do I suck it up and pay or do I run it for a while and see what else is out there.
Any advice would be appreciated. Thanks
Howell
4 tyres and a set of rear brakes isn't too bad?
  Clio 200FF
I worked it at
Tyres x4 £300 fitted
Rear brakes discs £150
Rear pads £20
Tracking £40
Belts £700-1000
Needs a CV joint as started to click £?
Total £1210-1510
Value of the car is probably around £2.5k
TheBandit
  Monaco172, Green1.2
Do you love the car? Pay for the work
Want to try something new? Somebody on here will snap it up
It's a sort of lose-lose situation, either you pay for the work to up the car value or the value drops significantly because it needs so much work
As @daveski says the maintenance is nothing out of the ordinary just a shame it's all due at once!
npt
  BMW 320d- 172 cup
Its a day's work, find someone who works on these nearest to you, always the easiest way if not doing it yourself
